my_own_plc
hello everybody
i have the same problem yesterday i bought an old machine to take out some equipments specialy the PLC and other things
so i try to acces to the plc but it had a passeword , i try to clear the passeword with master reset passeword with this passeword 65257...6 , but the slc 500 freez i tried a lot of times but without any results then i do clearing memory with a hardware master reset ; take out the battery and connecte the GND with the VBB connection for 60 seconds .
then when i tried to connect again to the PLC the message appear error code = 001h
any help to restore or the return back the plc to default statut and clear the fault error
thank you
thank you
