plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 21st, 2018, 05:50 PM   #1
ksmohammed
United States
ksmohammed is offline
Question Regarding Plant Pax Library
Good Evening,
I am curious to know, if its possible to use PlantPax graphics, face plates in Factory Talk View without utilizing its Add On Instructions (AOI) in the PLC program.
Old February 21st, 2018, 05:57 PM   #2
rupej
United States
rupej is offline
Do you mean, can you use certain parts of the graphics and roll your own connections for them behind the scenes? I suppose so, but it would be a lot of work.
Otherwise, no, the graphics require the AOIs to function.
Old February 21st, 2018, 06:00 PM   #3
ksmohammed
United States
Thank you for the quick reply. Yes, is it possible to use the graphics without using its AOI in the plc program. For example to show motor running on the graphics, is it possible to take a modbus register to indicate the motor is running?
Old February 21st, 2018, 06:19 PM   #4
rupej
United States
rupej is offline
Technically, yes that would be possible. But it would be so complicated that you would be better off just copying the graphic and add a color change animation.
Old February 22nd, 2018, 02:40 PM   #5
Kidblue
England
Kidblue is offline
Kidblue's Avatar
Yes. It may just be easier to use the AOI as it is though. In your example, you would just point the relevant ‘Running’ input condition of the AOI to your modbus address (the AOI only checks for a 1 or 0). The contactor feedback, motor tripped feedback inputs etc. can be turned off as necessary. The AOI can be configured as basic as you need it.
As already mentioned in previous replies, the faceplate graphics can be pretty complicated and cumbersome to work with, so it can be quite time consuming (some of the objects are grouped within groups of even more groups). I have modified several of the standard graphics to suit our applications, but it is not a 5 minute job (is possible, just quite fiddly).
Hope this helps.
Rob
__________________
Rob Howdle
.........For the Boys in Royal Blue !!
Old February 22nd, 2018, 03:02 PM   #6
ksmohammed
United States
Quote:
Originally Posted by Kidblue View Post
Hope this helps.
Rob
Thank you for the reply. I understand this job may not be as easily. I am asking this because of a project. Our company is only hired to do the HMI, the PLC programming has been already done. So there is no way we can implement AOI and utilize these graphics. My main objective is to utilize Plant Pax library with just modbuss address and not use their AOI.
Old February 22nd, 2018, 03:17 PM   #7
Kidblue
England
Kidblue is offline
Kidblue's Avatar
In a nutshell, yes you can use the graphics as standalone objects. However, to strip out all of the (heavily grouped) layers of pre-tagged, and parametrised sub objects, you may find it easier to just make your own. Each of those graphics are made up of several sub groups that control several functions in the PLC and are driven by many more sub AOI groups (Mode/Alarm/Interlocks/Permissives etc.) so you will need to allow quite a lot of time debugging them.
Presumably your modbus signals will still need to be integrated within the PLC code (to ultimately drive the new graphics)?
Rob
__________________
Rob Howdle
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Ethernet subnet question rocksalt LIVE PLC Questions And Answers 14 March 17th, 2017 12:01 PM
NAT question cncsparky LIVE PLC Questions And Answers 3 October 23rd, 2016 08:36 PM
New Plant Control Network billysmithde2 LIVE PLC Questions And Answers 16 October 1st, 2008 05:13 PM
How to Ask Questions The Smart Way Ken Roach LIVE PLC Questions And Answers 14 March 26th, 2007 08:12 AM
Step 7 question: How to compile library? bobby1234 LIVE PLC Questions And Answers 9 December 19th, 2006 08:16 AM
