plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 23rd, 2018, 07:39 AM   #1
merlin00724
United States
merlin00724 is offline
flex IE8 raw issue
I am having some issues with a 1794-IE8 flex module on a controllogix plc. this is measuring the weight of a tank on load cells. the scaling seems to be right with the module set for 4-20mA and the raw min/max is 0-30840, but with a measured 3.8mA from the transmitter I am getting a raw value of 40. which is showing the tank as not empty when it really is. we have about 12 tanks set up like this and they all behave the same, and have since being commissioned new. so I am not really going down the road of thinking I have an isolated hardware issue. if I simulate 3.7mA to the module then I finally get a 0 raw value.
any advice on how to tighten this up so that at 4 or 3.9mA I can get a 0 raw?
Old February 23rd, 2018, 10:16 AM   #2
Mickey
United States
Mickey is offline
Mickey's Avatar
That is 0.1 of 1 %, pretty small error. What is the engineering units (span)?
Can the 4-20ma transmitter be adjusted(calibrated)? If not you could do this in the PLC.
If it is just a high zero issue you could program a zero cut-off. Any thing below value xxx will show zero. Common method as most transmitters drift a little.
__________________
Mickey
If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else.
----- Chinese Proverb
Old February 23rd, 2018, 12:01 PM   #3
merlin00724
United States
Thanks for the input. A cut-off might be the way to go
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Factory Talk SE Trending issue snordvikqplas LIVE PLC Questions And Answers 0 February 24th, 2015 08:15 AM
Rockwell Flex I/O issue JohnCalderwood LIVE PLC Questions And Answers 5 July 25th, 2014 11:07 AM
Allen Bradley Power Flex 70 VFD fault 85 issue david n pittsley sr. LIVE PLC Questions And Answers 1 December 9th, 2011 09:38 AM
how to Open Wincc Flex 2005 sp1 HF7 in WinCC flex 2008 compact/standard/advance xohaibalam LIVE PLC Questions And Answers 7 October 13th, 2011 08:38 AM
Remote I/O Flex I/O Quick Change Tooling Fixture TamHoNutech LIVE PLC Questions And Answers 1 September 29th, 2005 05:46 PM
