Flex I/O - 1794-IE8 - Fault and Status
CplHunter
Feb 2012
IL
Can anyone give me an idea of what the I.Fault and I.Status represent on a 1794-IE8? I can't locate this info in any documentation.
I've read that chapter numerous times. Nowhere does it mention Fault or Status. Ditto on the appendix entry (data map) for the IE8.
I'll state that I'm new to Rockwell. Am I missing something which would be obvious to someone with experience? o_O
I think that the I.Status word contains all the .Underrange and the .PowerUp bits that appear underneath it in the RSLogix 5000 module-defined Tags.
The bit positions should be the same as are shown for Input Word 8 at the bottom of Page 44 of that User Manual.
As a practical matter you can use the explictly-laid-out .ChXUnderrange and .PowerUp sub-element tags in your logic.
I don't know the contents of the .Fault word. It's possible that it indicates a module self-test failure or something else that would be uncommon or difficult to test.
Hi, i have a configuration whit 1747-SN and 2 racks in flex i/o (1794-ASB). In the rack 1 i have 4 modules 1794-ie8, 3 modules 1794-oe4 and 1...
1,493
Hi, I am back again, still with the issue of getting the 1794-IE8 configured and getting the reading from 1794-IE8. I am using SLC 5/04 series C...
2,352
Hi guys, Recently one of our AB Flex 1794-ie8 Series A analog input module has failed and we replaced it with a new one but a new module is Series...
10,678
New at this so here it goes, Could anybody give me a basic overview of what this type of FLEX I/O does, its an '8 input analog module...
4,841
D
Have a small problem, when setting up 1794-IE8 using 4-20mA signal. With RS 5000 is there a way to offset the counts 0-33840? Im not sure how the...
4,411
dougiediner
D
