GE- Sinking, Sourcing
damper
Nov 2002
Tennessee, USA
Am a new user to this web site. I am a student doing a Industrial maintenance course and have a broblem. I have a GE PLC with a 24 DC input module that only acepts a sourcing input and i have sensers that put out a sinking output. Is there any easy way of combining the two? ( sensors are polarity sensitive)
Steve Bailey used to have a posting that described the "Pull-Up" and "Pull-Down" arragement for mixed signals.
I can't find it anywhere!
The best I can give you is the following...
http://www.plcs.net/dcforum/DCForumID1/2645.html
If you are "UP" on your electrical, you might be able to figure it out.
I'll have to post an update to Steve's if he doesn't do so.
Try here.
http://www.plcs.net/dcforum/DCForumID1/1974.html
At one time, on the old forum, I uploaded a couple of powerpoint slides showing how to cross-connect, but I can't seem to find a reference to it any more.
Anyway, here's a bitmap of a sink-to-sink connection.
Remember that when you cross-connect like this, the signal is inverted. By that I mean that in this example, when there is no object in front of the prox switch, the PLC input will be on. When the prox detects an object, the PLC input will go off.
Good morning all. I have never seen this done but I want to ask if it is possible. On an AB 1766-L32BWA, can you have some of the inputs wired as...
2,361
I have a client who has installed a control system which was designed offshore (ASIA), and uses a power system common to the Asian market. The DC...
1,927
Hi there, I have a 2 wire npn sensor. For example in this diagram: I'm guessing i should connect it to a PLC dc sourcing input as such? Would...
5,214
Hello again guys, I've read tons of informations on sinking and sourcing inputs and outputs, however there is something bugging me with this. I...
4,356
We are some students thinking of buying a logo!8 starterkit to connect diffuse photosensores to the digital input. some of the sensores already in...
3,301
