LOGO!8 sinking or sourcing DI
kenny_Powers
Feb 2017
bergen
We are some students thinking of buying a logo!8 starterkit to connect diffuse photosensores to the digital input. some of the sensores already in place are of the type npn with three wires. the question is.. are we correct in our understanding that the LOGO!8 has a sinking type input and we could connect sensores with PNP type, but that it requires a voltage divider if we are connecting NPN? the siemens s7-1200 says if the input is sink or source but we have been struggeling trying to find this info on the LOGO!8 RCE
I have never used the Logo8 but have used many Logo6.
They were all sinking on the embedded inputs. (you would need to supply +24vdc to the input if using a 24vdc model)
If you have existing NPN type sensors that you would like to use, just control a relay with the NPN sensor and have the relay control +24vdc to your logo input. (not ideal I know, but would be cheaper than changing the sensors)
I am not sure if you can get expansion modules with sourcing inputs.....maybe. If I get a chance I will have a look at that.
EDIT: I looked briefly and do not see any sourcing input modules for the logo.
Good Luck
BCS
Hello Team, I am desperate for some help with an assessment I have as part of a Level 3 general engineering course. I am in a role that is much...
351
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
291
Hi Lads, I want to implement a flood prevention system with my domestic water pump. The intention is to have the water pump cut off on a daily...
1,079
[Update: fixed a typo in the image.] See the image below, especially the blue-ish annotations. The three rungs ending in output coils -( ) are...
17
986
We need a Really Simple and Cheap controller that has a display or a Web Interface where we can change some set points. We were thinking about a...
1,047
