wincc to excel file
catalin78
Feb 2005
Constanta
115
Hello .
I am trying to get out some data from wincc flexible advanced to a excel file whitout succeeding .
If anybody has a ideea ... please asist ,thanks
I went to a course a couple of weeks back. There are some examples of writing scripts in the software CD supplied. I will see if I can post them over the weekend.
HTML table
I write scripts that put the data into an HTML table. This is basicly a text file with some formating for HTML. When I save the file I put .xls file type on the end. Excel will open it up and it looks normal. I also save the same file to a .htm file type and view the file during runtime and I put a link to it in smart access. I am traveling now but next week I can post some code if you need it.
I am at work now, and I don't have the CD. I will surf for it on the weekend and upload some of the examples if you want. Sure, give me your email if you want, and I will send them to you.
I have dial up at home, so if they are large, maybe monday might be better.
what data u need to export to excel
log data are stored in csv format wihch u can open in Excel
so if u want to record for example temperature reading u can make a log file and this will be stored in csv format
Trigger could be time-cycle or value cahnge-event. There are date-time, value and timestamp (.1 sec) in the csv-log-file.
contents of excel file
in the excel file i need to put the following data :
1.process values
2.alarms
3.date & time event ocurred
4.medium value between 2 process values recorded for the last 3 days
csv files can be imported in excel ? i mean can i import a single value to a excel cell?
On the WinCC V6.0 CD, under 'additional software' (from the main installation menu) there is a utility called 'Configuration Tool', this is the Excel add on. This adds an extra toolbar to Excel that allows you to do all your configuration via Excel.
I haven't used this as I am still running WinCC V5.1 which requires Excel 2000 and I am running Excel 2003, so I can't install the add on.
Paul
I browsed the CD that was supplied in the course that I took a couple of weeks ago. Much to my dismay, it was a lot of AVI files, about 16Meg each. They do go through how to create scripts and such, but do not go into detail about how to write vba-excel scripting, just how to start the process.
I asked the instructor if there were examples of the script writing on the CD, and he said yes. Obiously, he didn't know.
The course/or info seminar was available to all Siemens suppliers. I would call Siemens and ask about the WinCC Flex Seminar information that would be available to end users.
I bought the WinCC Flex STD for $495.00CAD. Unbeleivable price. The advanced was not priced, but give Siemens Help a call and find out about the documentation supplied.
Sorry for the misleading information, I could post the AVI's, but they are quite large.
Hi, I have to convert my csv file to an excel sheet in Wincc Flexible 2008 for which I have written the following code snippet: 'Alarm_Log.csv'...
5,264
hello guys... i m looking for example how to send excel recepi to wincc flexiable (HMI) and when click particular formula it will start using the...
1,847
Hello everyone. I'm trying to export data to excel from Wincc. My code is global action that executed every second that create excel filer per...
5,735
Hi guys, I'm currently busy with a Wincc project which requires me to dump field data and physical inputs entered by an operator on a Wincc scada...
2,063
Hello all, I am using Win CC v7.2, I would like to do a couple of data and information transfers to either ecel or csv ortext files onto the pc...
3,211
