wincc to excel file
This reads a csv file from a log and puts it into an HTML table. For excel change the .html to .xls and it will read it fine.
Dim fso, InFile, OutFile, i, hold, hold_format
Set fso = CreateObject("Scripting.FileSystemObject")
Set InFile = fso_OpenTextFile("c:\Logs\Change_DataLog0.csv",1, True)
Set OutFile = fso.CreateTextFile("C:\changes.html", True)
OutFile.WriteLine("<html><table border =1>")
Do While InFile.AtEndOfStream <> True
hold = InFile.ReadLine
hold_format = "<tr><td>"
For i = 1 To Len(hold)-1
hold = Replace(hold,Chr(34),"")
If StrComp(Mid(hold,i,1),",",1) <> 0 Then
hold_format = hold_format & Mid(hold,i,1)
Else
hold_format = hold_format & "</td><td>"
End If
Next
OutFile.WriteLine(hold_format)
hold_format = "</td></tr>"
Loop
OutFile.WriteLine("</table></html>")
InFile.Close
OutFile.Close
This pops up a save file dialog and saves a csv file to an excel file. I hope this helps getting you started. WinCC Flex does not support all VB script command but sometimes you can find a work aroung.
Dim filename , myvar
Dim fso, MyFile, i, file_length, hold, TempFile, file_name
Dim InFile, OutFile, hold_format, run_code, cycle_time
Const ForReading = 1, ForWriting = 2, ForAppending = 8
Dim start_time, stop_time, run_min
Set myvar = CreateObject("SAFRCFileDlg.FileSave")
myvar.FileType = "xls"
myvar.FileName = "Order_Report_" & Month(Date) & "_" & Day(Date) & "_" & Year(Date)
myvar.OpenFileSaveDlg
file_name = myvar.FileName & ".xls"
If file_name <> "" Then
' read csv file and write xls file
Set InFile = fso_OpenTextFile("c:\job_report.csv",ForReading, True)
Set OutFile = fso.CreateTextFile(file_name, True)
'add title
OutFile.WriteLine("<html>Order Report "& Date &" "& Time)
'add header
OutFile.WriteLine("<table><tr><td>Date </td><td> Time</td><td>Part Number</td><td>Quantity</td><td>Quantity to Date</td><td>Pad #</td><td>Operator</td><td></thead>")
'add data
Else
End If
Next
Loop
InFile.Close
OutFile.Close
End If
thanks charlesm , how should i proceed in the easyest way to put in the same file , the process data ... and some info about alarms ?
Thanks for the code :)
I would start by setting up an alarm log. The WinCC Flex help file should show you how to set this up to log to a csv file. Then create the script and paste in what I have changing the file path to match your log file path. Then call the script on a button click to start just to make sure it works. Then build on what you have working.
log values
Thanks CharlesM your a real saver , the second script works like it appends data at the end of data already in the xls file or overwritting?
Merry Christmas :>
catalin78 said:
Hello .
I am trying to get out some data from wincc flexible advanced to a excel file whitout succeeding .
If anybody has a ideea ... please asist ,thanks
I did it yesterday for MP270B 6" touch pabel. They don't tell that there have to be optional Compact Flas Card in OP. It's path is "Storage Card2" not the 1'st default "Storage Card".
I did Alarm history-log and one log for what operator have done.
In that panel have many ways get the .csv-file fe. ethernet or directly from the Compact Flash Card by card reader. I didn't need any script for that.
seppoalanen , i need to export alarm and process value in a excel file because these are the keys of the problem , and i use a pc runtime not op:)
Hi, I have to convert my csv file to an excel sheet in Wincc Flexible 2008 for which I have written the following code snippet: 'Alarm_Log.csv'...
5,270
hello guys... i m looking for example how to send excel recepi to wincc flexiable (HMI) and when click particular formula it will start using the...
1,852
Hello everyone. I'm trying to export data to excel from Wincc. My code is global action that executed every second that create excel filer per...
5,740
Hi guys, I'm currently busy with a Wincc project which requires me to dump field data and physical inputs entered by an operator on a Wincc scada...
2,066
Hello all, I am using Win CC v7.2, I would like to do a couple of data and information transfers to either ecel or csv ortext files onto the pc...
3,214
