Low vibration AC motor
kiran
Jul 2003
43
Has any of you used a "low vibration AC motor". I have to buy one for a spindle drive application on a surface grinder. Could you suggest some manufacturer.
Thanks.
"low vibration" can mean low mechanical vibration which is primarily a balance issue or low torque vibration in the shaft which is much more complex.
Since you mention grinding, this very well might be torque vibration because it can leave an undesireable grinding pattern in the finished workpiece.
Please advise which of these you are referring to.
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
135
I'm a beginner in the automation field and I've set up an automation system connecting several devices (datalogger, radio, etc.) via Modbus RS485...
215
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
146
I'm a newbie who started a job as a repair tech recently. I've had plenty of luck with ABBs, Allen Bradleys, and a few others, but I can't seem to...
160
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
87
