plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old April 12th, 2006, 12:05 PM   #1
brianafischer
United States
brianafischer is offline
Atlas Copco OpenProtocol
Hello,
I am looking for drivers and/or example source code for both PC and AB PLC based systems that use the Atlas Copco Open Protocol to speak to PowerFocus torque controllers.
Thanks for the help.
Old June 20th, 2006, 05:22 PM   #2
Lancie1
United States
Lancie1 is offline
Lancie1's Avatar
Let me know if you find any. I need a copy of the Atlas Copco air compressor internal program also.
Old June 21st, 2006, 10:03 AM   #3
jkrom
United States
jkrom is offline
jkrom's Avatar
About a year ago, I struggled for a whole week to get torque data from an Atlas-Copco PF3000 into a MicroLogix 1500 and came up with a solution that turned out to be the most convoluted code I've ever written. I have since come up with variations for SLC 5/05 and CompactLogix.
Anyway, I'll see if I can find a sample - although I have yet to meet anyone else that can understand how it works
If you have the option of taking data directly into a high-level PC-based system, I would definitely recommend that - as that is what the torque box is designed for.
Slightly OT - did you know that there is actually a type of dinosaur called the Atlascopcosaurus?
http://en.wikipedia.org/wiki/Atlascopcosaurus
__________________
-Jim Krom
Controls Engineer
Android Industries SHAP
Old June 13th, 2007, 02:52 AM   #4
zzr173
China
zzr173 is offline
Hi.At the time,I am developing MES. And I try to work to get data from an Atlas-Copco PF3000 now. But I found the openprotocol may not be I want, and cannot get correct data. May take me the sample?
Old June 13th, 2007, 06:29 AM   #5
jkrom
United States
jkrom is offline
jkrom's Avatar
Sorry, but I no longer work for the company that I developed that code for and do not have access to it.
__________________
-Jim Krom
Controls Engineer
Old June 13th, 2007, 03:44 PM   #6
Giz99
Canada
Giz99 is offline
Buy a PF with Devicenet and use that for information etc. It costs money for the Cards and interface but it is a less expensive then the hours you will be spending on this.
Giz.
Old June 28th, 2007, 09:33 AM   #7
Alessandro Santos
Brazil
Alessandro Santos is offline
Hello Jim,
I am Alessandro Santos and I work for Rockwell Automation Brazil. We have a customer who want to get data from a PF3000 into a SLC500 5/05. I am looking for references about this application and I have found your post.
I know that you are not working for Atlas Copco, so probably you do not have the files that you have developed, however I would like to ask you any contact inside Atlas Copco that I can have any reference. I tried Tech Support but I was not succesfull.
Best Regards
Alessandro Santos
Rockwell Automation
Old June 28th, 2007, 11:25 AM   #8
tbode
United States
tbode is offline
tbode's Avatar
Atlas Copco Open Protocol Example
Alessandro,
I did a VB6 project some years ago talking to PF3000 controllers via sockets in VB and sending the data via OPC to an HMI. I believe that this would work using the OPC interface in RSLinx to go to the 5/05 but I do not have one to test with. I may be able to send you the code template. I will need to check with the home office.
Old June 28th, 2007, 03:06 PM   #9
panic mode
Canada
panic mode is offline
panic mode's Avatar
we have code for PLC and PC (VB6 and VB.NET) but i cannot share it...
here is open protocol,
EDIT
cannot post it here, it's over 300kb limit so you may get it here
http://forums.mrplc.com/index.php?download=721
Old July 1st, 2008, 03:02 PM   #10
coreysimon
Canada
coreysimon is offline
I work for a company that has developed communication to all Atlas Copco tools via open protocol and can provide an OPC or DDE methods of communication as well as SQL database storage of rundown data.
Old August 18th, 2008, 04:20 PM   #11
RoyKok
United States
RoyKok is offline
Thumbs up Torque Tool Open Protocol
Kepware is about to release a driver for the Torque Tool Open Protocol. It was developed to interface with Stanley and Atlas Copco products supporting the Open protocol and will be available as a standard driver ($795). Beta is available now and the final version will be in the early September release.
Old January 12th, 2009, 03:01 PM   #12
rahonny
Malaysia
rahonny is offline
Cool PF3000 open protocol Atlas Copco
I am currently programming the PF3000 and DS using SQL, MSDE, MySQL and Oracle.
Anyone needs application to do some Data Acquisition from the Atlas Copco products can contact me! I am doing this for a living.
I will give an attractive quote. I also have some applications ready, especially for Automotive Industry. An application to capture torque data for SRS components.
Again you can reach me at
rahonny@gmail.com
Old January 13th, 2009, 08:37 AM   #13
RoyKok
United States
RoyKok is offline
Update on our Torque Tool Driver
Hi All, It's been released and has been tested with both Stanley and Atlas Copco Torque Tools. You can download it at www.kepware.com and it runs in a two hour demonstration mode, until unlocked. It is in use with several major automotive manufacturers. Thanks
Old April 5th, 2012, 04:12 AM   #14
rahonny
Malaysia
rahonny is offline
Hello All,
I recently received a lot of requests about the Atlas Copco Open Protocol apps whether I am still supporting them?
The answer is YES. Do send me your requests and I will get back you as soon as possible.
rahonny@gmail.com
Old April 1st, 2014, 11:13 PM   #15
Fitz-William
United States
Fitz-William is offline
Fitz-William's Avatar
Has anyone been successful getting torque and angle data from an Atlas Copco PF3000 into a SLC-5/05 via Ethernet? I am struggling to get this to work using an EEM (Explicit Ethernet Message) instruction in the SLC-5/05.
Please reply...THANKS!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Atlas Copco Master/Slave automatic LIVE PLC Questions And Answers 4 March 10th, 2005 04:08 PM
Atlas Copco PowerMACs panic mode LIVE PLC Questions And Answers 0 May 19th, 2004 02:00 PM
atlas copco hey4 LIVE PLC Questions And Answers 5 January 17th, 2004 07:06 PM
