Atlas Copco OpenProtocol
Contact me
Has anyone been successful getting torque and angle data from an Atlas Copco PF3000 into a SLC-5/05 via Ethernet? I am struggling to get this to work using an EEM (Explicit Ethernet Message) instruction in the SLC-5/05.
Please reply...THANKS!
Yes contact me for further details.
i worked for a company 2 years ago and we had to buy an interface board to communicate between (2) atlass copco units and a compact logix processor.
i no longer work there and do not have access to the information.
regards,
james
Resurrecting an old thread:
rahonny,
I am looking to get torque and angle data from a PF3000 into a Allen-Bradley ControlLogix PLC, over the standard Ethernet port in the PF3000 (not the add-on Ethernet card), to the Ethernet port on the PLC.
Have you done or could you do this programming job?
Atlas Copco Data Transfer
I am currently trying to transfer string data to a PF3000 Atlas Copco from my Compactlogix controller. Frist I scan with a barcode reader, which is connected via Ethernet to my Compactlogix. I do a MID "Middle String" and my Dest is called Trace_Serial_Number.
The Ethernet Generic Module created SINT tags both Input and output. I did a STOD "String to DINT. But now how do I move that data to the PF3000 Atlas Copco?
Will be offline for a few hours
Randy
Dear Experts,
Am New to working Atlas Copco - Power Focus Tool . In that Am Using Ab L75 - Control Logic Plc . So i want to Communicate with Atlas Copco To plc With Ethernet Communication . After Establishing Communication , I want to Read & write The datas. . I want to check Healthy Check Of tool and Fault Code after i want to read The torque and Angle Of Tighting tool . . So how to do this.. Please Help this support. If any one having Plc Coding mean Please share with me .. Its Very helpful ..
Thanks & Regards,
Arasan..
Thanks for the info. I actually messed around with a compactlogix and pf controller today and had them talking to each other via the field bus option in the pf.
Did you have any luck with this? I don't know If I have something setup wrong. Please take a look at the following images.
okay quick update. the issue was the size settings in the connection parameters. The size of the controller has to match the PLC. in my case, it was 5 (16 bit INT ) for input and output.
Verification?
Has anyone verified these settings?
I've put in the same connection settings into RSLogix5000 on a ControlLogix..
No ability to connect....
What about the settings TO PF? The pictures just show the data inputs from the PF?
Any ideas?
It was hard trying to find the software ECT for this drive. Finally, I found it but since it is very old it is not intuitive at all. Is there a...
107
Hi Guys, I'm looking for a download for the ToolsTalk software for atlas copco controllers (power focus). The laptop that had it died and of...
3,167
Hi I´ve been looking around the web trying to find programming software for Atlas Copco DMC drive series..(Example: DMC 50720) This far I...
2,506
Wizards, Has anyone used the wireless torque gun set up from Atlas Copco? I was asked to see if it would be an improvement to change over to...
1,295
I'm most likely out of luck here, but I'll give it a shot to ask... Does anyone have the following software? PAM Tools SAM Tools ProMotion...
20
6,951
