This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Aug 2002
recording hours on a pump with a vfd
whenever my pump is running, my plc starts a timer to record operating hours. It's very basic counter that counts the minutes the pump is on. The plc controls the pressure by an analog signal and variable speed drive and normally runs between 50% to 90% of full speed. Is it normal to create some logic to slow down the plc operating hour timer when the pump is not operating at full speed to reduce the maintenance intervals? for example, run the hour counter at 50%, 60%, 70%, 80%...
#2 |
Implicit in that strategy is the assumption that an hour at full speed produces significantly more wear and tear than an hour at half speed. If your experience tells you that your scheduled PM is late on pumps that consistently run at higher speeds but OK when the pumps run slower, then by all means create a speed-weighted timer.
I've never run across anyone who set up a PM timer like that. I think most places would just take a worst-case scenario and set up their timer on that basis, figuring that the cost of doing a PM sooner than necessary is less than the consequences of doing it too late. You just have to decide if it makes sense for your application. |
#3 |
As an alternative to a "weighted" operating time based on load, since timers in the PLC are "free", you could also consider several timers, each within a specific load range.
For example, one each could record operating time in: "under 25% load", "25 to 50% load", "50 to 75% load", and "75% to full load". This method may give you more significant operating data for maintenance considerations.
__________________
"Invention is 1% inspiration and 99% perspiration - Edison." This explains why so many engineers smell so bad...
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Sorting devices based on hours of operation | pickerel | LIVE PLC Questions And Answers | 14 | November 22nd, 2006 01:19 PM |
| motor alternating directsoft 32 on a DL06 | DRThorne | LIVE PLC Questions And Answers | 15 | November 9th, 2006 08:05 PM |
| VFD and Well Pump Question | Drake Lindsay | LIVE PLC Questions And Answers | 7 | August 24th, 2005 04:38 PM |
| Again and again. How to start? | Alex Pel | LIVE PLC Questions And Answers | 33 | December 31st, 2004 11:10 AM |
| cicode | Rich101 | LIVE PLC Questions And Answers | 11 | February 29th, 2004 08:58 AM |
