5 Sec Clock Pulse bit timmer
shresp
Aug 2007
Hetauda,Makawanpur
I am Using omron cx-programmer. In this programme the 1-sec clock pulse bit timmer is avalable in programme itself.I want to add new 5sec clock pulse bit in the PLC ladder diagram.I am able to add new symbol named 5-sec clock pulse bit in the programme but this did not work as 5-sec clock pulse bit timer.
How to add new clock pulse bit timmer? Not only symbol, want to add timmer function.
I don't know CX programming - this info is generic.
Set up a counter with a value of 5 (or 4). Use the 1 sec to pulse the counter. Name the counter 5sec. Use the 'counter true' signal to do 2 things - pulse your 5sec bit, and reset the counter.
This will give you a 1 scan pulse every 5 seconds.
how do I create a 1/10thsec clock pulse, if any one could tell me that would be great. Im using Syswin
2,368
Hello. This is one for the Mitsubishi experts. I need to measure the time for a remote device's to return process data sent from the i-QR...
17
2,126
Hello I need to make a pulse every second of RSlogix the 5000th I have read this thread through and tested it as rdrast writes in Post # 14...
6,055
Hi everyone, I have a small project for an industrial site entry gate system. It's running on an old Melsec PLC, and I have a new Shihlin PLC...
131
Anyone have access to Melsec Medoc plus 2.31a that can either open a file (.pcd zipped in link below) and send a PDF/screenshot of the ladder, or...
383
