AB DH485 pinouts?
timbo_uk
Nov 2005
Bradford, UK
336
Hi again gurus :)
I need to bring a second PLC (SLC 5/03) under control of a Telemec XBTGT2220 HMI. The HMI is all ready connected to a Micrologix 1000 with DF1 protocol through the HMI comms port 1 (9 pin DIN).
There is a second port on the HMI marked RS485. This can be configured as DH485. I need to connect to the 5/03 via DH485. This can be done, but again wiring is the issue.
Schneider (Telemec) say I need cable XBTZ9732 and adaptor XBTZG939. But this combination is only 2m long, I need 20! Nobody will tell me the pinouts; I dont want to spend another £45 on this job just to find the connections!
The com2 socket on the HMI is just an RJ45 socket:
This is the socket info from Telemec. Anyone got the pinouts for the DH485 socket on the SLC 5/03?
Can I just use a standard cat5 cable?
I really dont want to blow any of the ports!
Has anyone done similar and made a note of the connections?
Heres Hoping :)
Thanks Mickey.
Looking at this it keeps mentioning the AIC unit. It also looks like the cable is just a straight through, so can anyone say if a cat5 cable will do the job direct without using any AIC's ?
Tim
Be careful!! There is 24VDC on the port of the SLC5/03. Take a look at the diagram of the cable again.
Ooops.
Tired now on the night shift; only 4 hours sleep last night (or yesterday, whatever it was!)
P1 COLOR FUNCTION P2
1 RED CH. B TX/RC 1 TOP
2 BLACK CH. A TX/RC 2
3 BROWN +24 VDC 3 **
4 WHITE SIGNAL GND 4
5 BLUE TX-EN 5
6 DRAIN EARTH GND 6 **
7 GREEN SIGNAL GND 7
8 ORANGE +24 VDC 8 BOTTOM
I cannot see how these relate to the telemec diagram.
Think I should leave it untill tommorow night. Brains hurting now o_O
Hello all, i have seen a few things here and there about connecting to a panelview 550, however i still would like to ask a few things, I have...
147
Hi all, I had a setup with 2 Micrologix 1100 connected to a Panelview C300 over DH-485. I was mandated to upgrade the HMI, and proposed to...
909
Hello, We have an older machine that has a standard PanelView (2711-T10C3) connected over DH485 to a SLC 5/04 PLC via a 1761-NET-AIC module in...
689
Hi, I have a SLC5/03 connected to a working HMI via RE232 port, and connected to a broken HMI via DH485 (RJ45), I want to use the cable that used...
3,357
Hey all, long time reader but first time poster here. I've been tasked with an odd one and was wondering if anyone else had experience in this...
17
5,385
