plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old April 30th, 2009, 11:20 AM   #1
kittydog42
United States
kittydog42 is offline
kittydog42's Avatar
Automation Direct & GE Fanuc VersaMax Micro: 24VAC On 24VDC Inputs?
I have been transitioning new applications to the GE Fanuc VersaMax Micro 14 from the Automation Direct DL-05 due to issues that I have been having over the last 5 years with digital input failures with the latter.
I had tinkered around with applying 24VAC into the DC inputs on the Automation Direct, and it seemed to work with some filtering logic to remove the frequency oscillations. It seemed as though the hardware is isolated and can take it without damage. I remember a thread about that but can't find it now.
Does anyone know if the GE Fanuc VersaMax Micro can accept this voltage as well? They will not explicitly allow it (because it is not on the specs)if I ask their tech support department. It seems to work but I don't know if it will damage the equipment over time.
Old April 30th, 2009, 12:26 PM   #2
rdrast
United States
rdrast is offline
rdrast's Avatar
I can't speak to that with confidence, but it seems that you would at least damage the protection built in to most digital inputs.
Why not use solenoid drivers to gracefully convert the 24VAC to 24 VDC? Not terribly expensive, and they can usually fit right on the terminal strip in place of normal straight-through terminals.
__________________
How to ask questions the SMART Way!
Look First, Ask Second!
Old April 30th, 2009, 01:19 PM   #3
Lancie1
United States
Lancie1 is offline
Lancie1's Avatar
Kittydog,
This may be the one you were thinking of. I remembered it also.
http://www.plctalk.net/qanda/search....archid=1293670
Old April 30th, 2009, 02:03 PM   #4
kittydog42
United States
kittydog42's Avatar
Lancie1, that is what I was looking for. Thanks!
Old April 30th, 2009, 08:18 PM   #5
RussB
United States
RussB is offline
RussB's Avatar
A side note:
The GE Fanuc Series 1 and Jr. had I/O that was designed for 24 Volts AC or DC.
Ahh, the octal days.
__________________
LEARN something today so you can TEACH something tomorrow.
DETAIL in your question promotes DETAIL in my answer.
Dominus Vobiscum <))>(
"Where is the wisdom that we have lost in knowledge?" T.S. Elliot
Old April 30th, 2009, 08:53 PM   #6
Lancie1
United States
Lancie1 is offline
Lancie1's Avatar
The Good Old Days!
Russ, you have created a PLC term for "the good old days". Very funny!
Old May 1st, 2009, 11:15 AM   #7
kittydog42
United States
kittydog42's Avatar
If you miss octal, program with DirectSoft...and you won't miss it for long!
Old May 1st, 2009, 05:31 PM   #8
keithkyll
United States
keithkyll is offline
The input to a PLC is an optoisolator. The diode (LED) inside can't take more than 5 volts reverse voltage. I suspect this is what's getting damaged when you hit it with AC.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
GE FANUC Series One Lithoservice LIVE PLC Questions And Answers 8 October 24th, 2007 06:39 PM
GE Fanuc VersaMax Easy Program Store Device CaseyK LIVE PLC Questions And Answers 2 September 13th, 2004 06:38 PM
GE Fanuc T/W Interface I/O help needed Johnny T LIVE PLC Questions And Answers 4 June 28th, 2004 02:26 AM
GE Fanuc Versamax HSC ComReqs BarryP LIVE PLC Questions And Answers 2 July 18th, 2003 05:29 AM
GE Fanuc Automation to Acquire Intellution from Emerson Rick Densing LIVE PLC Questions And Answers 1 October 22nd, 2002 01:57 PM
