plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old May 7th, 2009, 01:17 PM   #1
Killercal
Canada
Killercal is offline
Adding a Module in RSLogix 5000
Hello all,
I'm trying to add a Flex I/O module to a current system for a testing/trial.
Chassis set up:
[0] 1756-L61 (controller)
[1] 1765-ENET/A
[2] 1765-ENET/A
[10] 1756-HSC
[11] 1756-HSC
[12] 1756-HSC
I am having trouble with the 1756-HSC cards missing counts and would like to try to use the 1794-VHSC in there place. I have a 1794-AENT so I will be putting this on the Ethernet network. When I open up my program and right click on the [1] 1756-ENET module, the "New Module..." is greyed out. Can I use this card to connect the flex I/O network or do I need a bridge card (i.e. 1756-ENBT?)
Thanks,
Killercal.
Old May 7th, 2009, 01:21 PM   #2
kamenges
United States
kamenges is offline
kamenges's Avatar
You need the bridge (-ENBT). The ENET module can't be used for I/O.
Whay do you believe the 1794-VHSC will perform any better than the 1756-HSC?
Keith
Old May 7th, 2009, 01:24 PM   #3
jkerekes
United States
jkerekes is offline
jkerekes's Avatar
Are you trying to do this online? You need to do this offline. The ENET module is fine.
Old May 7th, 2009, 01:27 PM   #4
bkottaras
United States
bkottaras is offline
I agrre with the above post. You must be offline to add the module.
Don't forget that you also have to configure your AENT for slots, modules, etc when you add it.
Just a reminder.
Old May 7th, 2009, 01:32 PM   #5
Killercal
Canada
I personally don't think it will change anything at all, but the customer wants to try this method as they have the Flex I/O working on another machine which is some what similar.
Jkerekes, I am offline right now.
So you both contradict each other, can I use the ENET or not?
Old May 7th, 2009, 01:35 PM   #6
bkottaras
United States
The offline part I'm sure.
ENET, haven't tried it, only ENBT and it worked.
Old May 7th, 2009, 01:38 PM   #7
bkottaras
United States
Must be offline and must use ENBT
Just tested!
ENET won't do.
Old May 7th, 2009, 01:41 PM   #8
Killercal
Canada
Thanks all. I will have to search for a ENBT module!
Old May 7th, 2009, 01:46 PM   #9
jkerekes
United States
jkerekes is offline
jkerekes's Avatar
The 1756-ENET/B module performs two primary tasks:
1.
Control of real time I/O data (also known as “implicit messaging”)
in conjunction with a Logix 5550 controller. The Ethernet module
may serve as an adaptor, interfacing the I/O modules to the
network, or as a scanner, sending and receiving data between the
controller and the network.
2.
Support of messaging data for configuration and programming
information, operator interfaces, etc. (also known as “explicit
messaging.”).
What CLX revision are you using? I don't have an ENET module to try, but offline Logix5000 allows me to add a Flex I/O "rack".
Old May 7th, 2009, 01:51 PM   #10
Killercal
Canada
V17 for RSL5000 and V16 on the CLX processor.
upon further investagation we have ENBT cards just set up as ENET cards in the tree. I will change this and work from here.
Thank you all for you help.
Old May 7th, 2009, 02:12 PM   #11
bkottaras
United States
ENET/B will work, ENET/A will not work.
Just ried it.
Old May 7th, 2009, 09:33 PM   #12
Operaghost
United States
Operaghost is offline
Operaghost's Avatar
Darn you bkottaras!!
I started reading this going "series B, series B" and you stole my thunder!
ENBT is better (more throughput capacity) but Series B ENET should work.
However, how do they think a remotely located module will outperform a local module? Seems backwards to me. Of course it will probably work though!
OG
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
PID Control Action Mode in RSLOGIX 5000 plcnovel LIVE PLC Questions And Answers 9 May 4th, 2017 10:31 AM
Help a RSLogix 5 guy learn to search RSLogix 5000 wildswing LIVE PLC Questions And Answers 6 March 25th, 2009 12:05 PM
Rockwell RSlogix 5000 activation without floppy matt_sd LIVE PLC Questions And Answers 6 March 11th, 2009 09:15 PM
RSLogix 5000 data file advice/preference rta53 LIVE PLC Questions And Answers 18 June 29th, 2006 01:10 AM
RSLogix 5000 eastkodakguy LIVE PLC Questions And Answers 2 July 3rd, 2002 11:28 AM
