This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Jun 2008
SLC 5/04 Fault
The processor has an immediate fault light when power is applied. The processor is good and the power supply is good. Does anyone have or know how to get a pin out for the 1746-A13 chassis or the SLC 5/04?
#2 |
A "pin out for the 1746-A13 chassis" ?
Are you wanting to troubleshoot the PLC by hooking a scope on the backplane bus ? I am guessing you are asking how to connect to the serial port on the CPU. For that you need a null-modem cable. Or make you own cable with the pins connected 2-3, 3-2, 5-5. When you go online with RSLogix, you should configure a serial "RS232 DF1 device" driver in RSLinx. Use the "autoconfigure" button in the configuration dialog to automatically sense the baudrate etc. Then when online in RSLogix go to the "Processor Status" and investigate the Major Error status word S:6.
__________________
Jesper
#3 |
What is the exact LED sequence?
You realize it's normal for a SLC to fault when it's (missing or different?) program does not match the I/O config. Follow Jesper's wise advice and get online to check the fault code and the status of your SLC program (make sure it's really what you expect to have loaded). And, welcome to the forum, fellow Okie! Paul
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants. "You can lead a horse to water but if he's got his head up his as$ he may die of thirst anyway." |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| slc 5/04 cpu fault and not output card power | blamison | LIVE PLC Questions And Answers | 1 | July 24th, 2009 11:39 AM |
| Can't connect to AB SLC 5/04 (Fault) | TomBrady | LIVE PLC Questions And Answers | 7 | May 26th, 2009 03:03 PM |
| SLC 5/04 + 1747-SN,B passthru to Panelview | paperboy4828 | LIVE PLC Questions And Answers | 2 | March 2nd, 2007 02:18 PM |
| SLC 5/04 Rack fault - How to Ignore? | skyfox | LIVE PLC Questions And Answers | 9 | December 2nd, 2006 08:01 AM |
| SLC 5/04 fault???? | john paley | LIVE PLC Questions And Answers | 9 | February 7th, 2003 06:59 PM |
