Mitsubishi plc melsec fx-48mr
Oct 2010
Juarez
I am trying to get programming software & cable to upload ladder program from a plc fx-48mr, somebody knows which cable and software I need to get?
id recommend GX iec developer, but gx developer or melsec medoc would work as well
the cable is called SC09 FX i think, can find them for 10 bucks on ebay
ok guys, lets back up a bit, the OP said a FX-48MR, this is one of the first Mitsi PLC's they built. You need a F2-20GF1 converter with a SC03 cable. These items are harder to find than hens teeth. Ask me I know. I have one of these beasts on site, have the converter, the software, no cable. Luckily I do have a hard copy of the program, so the first sign of trouble, its out and becomes a door stopper.
It is different to the FX2 series which use the SC09 cable and the newer FX3 series which use USB, Also to my knowlege, i could be wrong though, the FX series only works with MEDOC
Good luck in finding what you need.
When you guys across the pond read this I will be getting ready to leave and have one of these 🍺. enjoy your weekend
Hi friends,
I am new to this post & had not gone through the whole post. But I remember one good feature which Mitsubishi FX2n provides i.e. you can connect PLC via MMI if it is also from Mitsubishi ( GOT series). They usually gives RS232 Port on GOT & FX2n can be accessed through GOT by using simple cross cable with 9 pin connector on both sides, can be easily soldered at lab.
Best of luck
(n) There are so many innacuracies in this post i dont know where to start.
You have your FX and F series totally mixed up....
- The FX-48 MR is not the first PLC's that Mitsi Built, thats the F
FX: http://www.plcsweden.se/se/art/plc-mitsubishi/fx-system/fx/fx-48mr-es.php
F: http://www.lektronix.net/equipment/16310/mitsubishi/plc/f1-20mr-es/f120mres/
- F2-20GF1 was for the F Series, not the FX:
http://www.essentialautomation.co.uk/ea82.html
- The SC09 will work with FX:
http://www.essentialautomation.co.uk/ea83.html
- GX Developer will work with the FX series
http://www.mitsubishi-automation.com/products/software_gx_developer.htm
Tragically is correct FX 48mr will be fine with an SC09 Its the F1 that needs a converter and SC05 cable Unfortunately I was around when these things were new. Regards Badger
Don't use GXIEC as you can only upload in stl GX Developer will show code in ladder, the SC09 cable will be fine.
I have an 80's PLC, Mitsubishi K2NCPU that needs replacing. Is there a software / cable available to upload and print the current PLC program? Thanks
946
We received a cell that has a MELSEC Mitsubishi FX 2N-80MR PLC installed. We need to access the PLC program for troubleshooting and additional...
1,982
Dear all, Hope all will be fine.I am here with a problem. I have to Program and configure the Mitsubishi PLC Melsec FX3U-80M. i am using GX...
3,998
Dear Experts!!!! I want to communicate my "XG-8000 Series Keyence Vision camera" with Mitsubishi Q06UDV PLC over RS232C non-protocol mode. My...
2,528
Hi, I am wanting to get an FX2N-128 to communicate with Intouch over RS485 using a FX2N-485-BD add-in comms card, FX485-232 converter and using...
2,527
