dcovemac
Hey all,
Made myself a decent application in FactoryTalk, when testing the screens with the "test display" btn everything works fine.
Then I tried to compile..
I always get these errors:
ERROR: Unsupported feature=Use Variable Min/Max; Component type=Displays; Component name=Overview; Object name=NumericInputEnable2
ERROR: Unsupported feature=Use Variable Min/Max; Component type=Displays; Component name=Overview; Object name=NumericInputEnable1
ERROR: Unsupported feature=Use Variable Min/Max; Component type=Displays; Component name=[VAR_Length]; Object name=NumericInputEnable3
Indeed I'm using NumericInputEnable's with variable min and max, but that shouldn't be a reason I can not compile..
Does this sounds familiar?
Thx in advance
Thx in advance
