FactoryTalk Directory error
40mpg
Dec 2021
Oakland, CA
82
Hello all,
I am trying to "Specify a FactoryTak directory" to another computer on the network. But my local admin username and password generates a " You must be permitted the Change Directory Server user rights policy to change the directory....."
So I go and run "FactoryTalk Directory Configuration Wizard" select local directory and type in my local admin user and pass....then I got an error message that says
" Unable to install a Policy. A policy file was not found or is incorrectly formatted. Exception from HRESULT : 0x80044003
This is a fresh install of FactoryTalk Studio Enterprise
What am I doing wrong...there is no other local admin user name and password..
SOLVED: I typed the local user with the domain...dun dun dun..
In FactoryTalk View Studio - View Machine Edition, I get "Failed to open the FactoryTalk Private Directory" error when opening a project. I can...
18,415
Tengo este problema luego de reiniciar el PC, he encontrado solucion cuando el proyecto es ME, requiero una solucion para un proyecto SE La...
1,466
Hello all, I have an example scenario 1. Host serving FactoryTalk Directory server is on 10.125.54.32 2. Client 1 is on host 10.125.54.33 ...
1,540
Hello, I am stumped with logging into the remote directory located on a server setup with a Network Distributed Application. I can't seem to get...
1,131
Hi all, Im having some issues and hope you can help. A customer wants an existing Panelview Plus connected to their Active Directory. At the...
2,285
