40mpg
Hello all,
I have an example scenario
1. Host serving FactoryTalk Directory server is on 10.125.54.32
2. Client 1 is on host 10.125.54.33 , points to the directory on .32 OK.
3. Client 2 is on host 10.115.24.19, I want to point this to the directory server on .32
Client 2 can ping the FactoryTalk Directory server on .32 fine and vice versa
Client 2 FactoryTalk version is same as the Directory Server
I have been trying and failing to "Specify" Client 2 to use the directory on the server...do I have to put Client 2 on the same subnet as the server? or IT can do routing magic on the network?
P.S Rockwell document says port 7710 is used for FactoryTalk Directory Server, but when I look at ports in listening I don't see any entries for port 7710 on the server. Am I interpreting the port number usage correctly?
Thank you all!
Thank you all!
