Factorytalk View ME linked to Active Directory
MatStand
Jan 2021
Nordsjaelland, Denmark
Hi all,
Im having some issues and hope you can help.
A customer wants an existing Panelview Plus connected to their Active Directory.
At the moment (travel restrictions), it is not possible for me to access the site and network.
Is it anyway possible to add windows-linked groups to a server i cannot acces, if i get the stationname, ip-address, etc. and the group names. Then create a .mer file for the customer to download.
If the names are exact, will it be able to auto-detect the server?
Best regards
In Active Directory, the network controller PC has to actively identify and register every client computer that is to be connected to the directory for management purposes. An AD User **can** log on to the network, just with their domain account (DOMAIN\USERNAME), even on a non-AD client, as long as AD is set up to allow that.
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
157
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
132
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
179
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
121
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
201
