bgtorque said:
Unfortunately, you need to install versions in order. thus, if you have v19 installed and you need v18. you need to unistall v19 first and then install v18 and then v19 again...
OG,
bgtorque did mention v18 and v19 specifically, so I don't think he's referring back to pre v10 installations?
bgtorque said:
...I have been through this loop umpteen times now. You may be worthwhile clearing out your registry values too and the initial uninstall.
Umpteen times? I don't doubt you, but I am curious as to what's happening here? I'm sure this is not the norm?
Can you remember what, if any, error messages you got?
As far as I'm aware, the versions can be installed in any order as required. I recently re-installed v10-v13 on top of v15-v20 without issue. I've done similarly in the past. I know you can run into some issues with older versions overwriting newer version DLL files, etc., which usually requires re-installing the newer version(s) again, but that hasn't happened to me so far.
Tip: Usually, to open a particular version of RSLogix 5000, one opens the *.ACD file and it auto loads the correct version for that project file. If, for instance, you wanted to start a project from scratch, using a particular version, then look in...
Windows 32bit:
C:\Program Files\Rockwell Software\RSLogix 5000\ENU
OR
Windows 64bit:
C:\Program Files (x86)\Rockwell Software\ RSLogix 5000\ENU
Here you'll see individual folders for all the versions you have installed. In the
Bin folder, inside each version's folder, you'll find the
RS5000.Exe file for that version. If you start RSLogix 5000 from the version folder's executable, it will open in that versions environment. Look at
Help/About to view current version. You could then also create shortcuts on the desktop or in a folder for each version's executable if you wish for convenience.
MikeUK said:
Is there anyway to determine which firmware product/firmware Rslogix 5000 actually supports?
This might also answer your question.
G.
