Drew Ethridge
I have a small system with an L33ER controller communicating with three 1734-AENT modules. I used the GSV command to get the status of the ethernet modules.
Yesterday two, and possibly all three, AENTs stopped communicating. I can't say whether it was simultaneously or not. Cycling power resolved the problem.
The only thing that I could find that looked unusual was that the "Task Overlap Count" was quite high, around 3000 after several weeks of use. I had inadvertently left it at 5ms from when I was testing and had not increased it when the system was deployed.
Would these overlaps eventually cause the AENTs to drop offline?
Is there anything else I should be looking at to find the root cause?
Lastly, I understand that "16384" means good, but is there any documentation as to what other numbers mean? I was seeing 4096 and 12288, which like 16384, are simply multiples of 4096.
I said "several weeks" of running. But that was with only with one AENT. We just added the other two 7-10 days ago.
