1734-AENT upgrade firmware
Jan 2008
Ontario
161
I had a 1734-AENT point IO adapter go bad. It was a series A F/W 3.006
I order a replacement, however it was a 1734-AENT series A F/W 1.033
I have installed it, but when I try to change the major revision in the project from 3.006 to 1.033 it complains that:
"Failed to modify properties.
Failed to set the 'Major' property (One or more modules in chassis are configured for Unicast and Unicast is not supported by this module's major revision)"
So I figured I need to upgrade the firmware and downloaded the latest firmware from the rockwell site (F/W 3.012). However even after downloading and installing the Controlflash firmware patch, when I open up controlflash and select the 1734-AENT, then select the adapter in the ethernet driver and click next, it doesn't allow me to select any firmware to upgrade. The selection screen comes up but it is not populated by anything.
Any ideas?
I have a system where a 1734-AENT module died. It was FW Version 5.001. I have a replacement module, FW Version 6.011. My software is Studio...
4,964
Hi everyone, new to forum. Since very long time i having issue with 1734-AENT module, after some period of time its keep stuck in error (simmilar...
611
Hi All, Have got a problem which i first thought to be a network problem but now starting to think we have got a broken 1734-AENT PointIO unit...
29
4,486
Hello. My facility has Point IO modules (on a separate cabinet) which is connected to a controllogix PLC via 1756-EN2T module. We lost...
1,408
Hello, There is a small test rig in our work which is sometimes salvaged for parts. The test rig is connected to a small robot used for training...
1,634
