1746-HSCE and LOGIX5000 Question
Killerabbit
Jun 2014
Fort Worth
I am upgrading an SLC system to Logix5000. I have a compact logix processor and a 1746-AENTR in the SLC rack. I have an encoder connected to the HSCE card. I get the encoder counting, but it counts up in both directions. I have looked at the book and tried changing the up/down bits. The encoder is connected to a+/a-. Maybe someone could help.
thanks
Tom
A single channel encoder can't be used to determine direction of rotation. All it can be used to do is count pulses unless you have another device that can tell the counter card which direction the encoder is turning. Since you haven't mentioned such an input I assume you don't have one.
Keith
If you have connected ONLY A+ and A- then it cannot tell what direction it's going. It would either need to have a direction or the B+ B- (if it's a quadrature encoder) to know count up/down.
thanks
Tom
Hello Tom, I'm trying to do the same thing HSCE card With 1746-AENTR but I have no pulses in the input word, my counter config are good, how did you do your config ?
I had a 1746-HSCE go suspected bad. have to swap the card in the morning. Other than dip switch settings is there any configuration to do?
1,028
Hi there, I have a machine where was a servo with extra encoder. That encoder had resolution 100ppr/5V. We did replace complet servopack (...
951
I have a SLC 5/05 processor and I am trying to reference an output from a High speed counter card to be used elsewhere in the PLC. The output...
1,642
I am upgrading HSC modules and have some questions. I can't attach the manuals for reference as they are too large. 1746-HSCE uses M0:e.1/4 for a...
1,655
Processor Error Message: G file configuration error.. user program G file size exceeds capacity of the module. I cannot seem to find any data...
2,042
