1746-hstp1 stepper module
Sevenfins
Sep 2019
Iowa
I have been unable to make my stepper motor move.
I was hoping for an example on rs500 that I could maybe look at. Or maybe some advanced help. I'm close, I know it.
One of the questions I have. Will turning on bit 10 on output word 0 during config output the correct voltage I need from the dir +/- when I am trying to home it?
Right now I have that turned off when I go to config.
Currently what happens is:
First scan turns on my config bit which sets up the specs I want. IE COP N70 >O:6.0 (Which is like... Home limit, ect)
the fault disappears and it goes into run mode.
I then copy an integer like N:80 that is all 0's into O:6.0
Then I should home it, right?
Well. I give the command for CCW limit find... However. The Run stays green and the CW movement turns on.
The motor moves really fast for just a second and then stops.
May have bitten off more than I can chew this time. I have lots of AB experience, but no experience with this module. I am having a very difficult...
1,843
I am a new employee of a Systems Integrator company. One of our projects requires us to replace Allen-Bradley SLC 500 modules with ControlLogix...
5,256
Good Morning all, So I'm stumped, we have working a SLC 5/03 with 1746-HSTP1 module running a automation direct STP-DRV 80100 driver and 34127D...
1,640
Hi all, I need some help fixing an ongoing issue I’m having that involves the 1746-HSTP1 stepper module. The equipment randomly shuts down due...
1,763
Hello all, Well I am back. I have been using and learning a lot about the SLC500 and I am able to use the Input / Out cards / Analog In / Out...
32
10,068
