1746-L73 Major Fault Code 60
oldnerd
Mar 2011
Al
94
I have a contrologix 1756-L73 processor that has been intermediately giving a type 1 code 60 fault on power up. I changed the ESCM module and placed an SD card in, now a few minutes after it boots I get type 1 code 61 fault. This does not happen at every power up just intermittent. Has any of you ran into this problem before? Talked with tech support an this was not much help.
Hi, having some issues with scalings (SCP commands) with some Vegapuls 65 guided wave radar level transmitters. I've set the min/max in the...
186
I had a 1746-HSCE go suspected bad. have to swap the card in the morning. Other than dip switch settings is there any configuration to do?
1,029
Happy Friday everyone! I recently installed a new module, 1746 NIO4I, into the last slot on this chassis. Got the normal IO mismatch fault, added...
1,576
Does anyone know where to get either new or aftermarket 1746-N3 connectors and cables for SLC 32 point discrete in cards? I have a used MCC that...
1,248
I am looking to replace a SLC5/05 processor with an AENTR adapter. Configured the rack in a compactlogix. The connection to all of the cards in...
2,324
