1747-CP3 and serial cables
BigMac
Mar 2003
Toronto
18
I cannot connect mu 1747-L532 processor to PC using regular serial cable DB9 f/f. I'm interesting the difference between 1747-CP3 cable and regular serial cable.
Normally 2-3, 3-2, 5-5 cable will work.
Correct pinouts for CP3:
2 - 3
3 - 2
4 - 6,1
5 - 5
6,1- 4
7 - 8
8 - 7
Problem possible in Channel 0 configuration inside PLC, it may not be set for DF1.
By "regular serial cable" you probably mean a "straight through" cable where each pin connects to the same pin on the other side. That won't work between a PC and a SLC-5/03.
Because the SLC-5/03 serial port is a "DTE" type port, just like the one on your computer, you need to swap the transmit and receive pins. That's what's done inside the 1747-CP3 cable, as well as some handshaking jumpers that Contr_Conn pointed out.
Hey guys, Setting up my new laptop on windows 11. Got all my software working in Ethernet/IP. Now i'm trying to connect into older PLC running...
1,361
Good Morning , I'm getting ready to replace some old laptops with Window's 10 laptops. What would be the USB version of the 1747-CP3 ...
1,413
I've got an ml-1400 inside of a sealed can, with a cmore hmi connected with the standard automation direct cable. Can I simply use two breakout...
1,751
This past weekend I created a "Cable Voltron" where I use an Ethernet Patch Cord as a base and put different ends on it (example...
2,353
Anyone know if making my own 1747-CP3 (female DB9 to female DB9) equivalent cable will work like the the genuine stuff. I'm trying to use it with...
6,030
