1747-L542B vs 1747-L552B/C
bwhite
Jul 2006
Lakeland, FL
53
Besides the fact that SLC 5/05 uses Ethernet instead of DH+, are there any major differences between the 2 processors?
I'm about to revive a mothballed small factory that has a 5/04 in it and want to use a 5/05 for the Ethernet capability for obvious reasons. My thoughts are that there is no problem swapping the processors but wanted to check with you guys first.
Ben
The 5/05 processor features additional functions, but it should still support everything that exists in the old program. As jstolaruk already mentioned, you might need to modify any messaging that existed in the old program, since the 5/05 does not have a DH+ comm port.
Also, just a reminder that if there were any panelviews talking to the 5/04s, it is likely that they will be unable to talk to the the 5/05s unless they also have Ethernet available.
Thank you for the replies. No, there's no DH+ going anywhere else. It used to run to a SCADA node via an S&S card but we're replacing all that with new,,, thank goodness.
hello I am getting a 57h fault - Specialty I/O module has not responded to a lock shared memory command within the required limit. Fault randomly...
86
We are in the process of upgrading a controls system. The existing system is a SLC500 with some IO cards and a 1747-SDN module communicating to a...
552
se me desprendieron los cables del cable usb quiero soldarlos pero no se como van los cables si alquien me pudiera proporcionar una foto o como...
406
Hello, I've got a project where I need to get information from two ABB ACS880 VFDs onto the plant operator's screen (or alternatively, onto...
23
2,611
Hi Newbie here :yeah: Can one of you experts help me with setting up a simple BTR and BTW to just test 4 analogue inputs 4-20ma (1974-if4i)...
1,002
