1747-Pic Compared To the 1747-UIC
jdb
Dec 2006
michigan
32
Can Anybody Please Tell Me what The Differance Is? I Am Just Getting Started On PLC Programming. I Have Purchased The PLC Tutor Book From The Site.
I Was Given A 5/02 Processor And A Few Input And Output Cards Just To Play With.
However I Can Not communicate With The Processor. I Was Told Because My Lap Top Has the USB And Not the Serial Port I Would Need the USB To Serial Port Adaptor And The 1747-PIC. After Purchaeing this I Still Can Not Communicate. I Have Purchased The SLC 500 With RSlinx Standard Software.I Was Reading A Post On Here About the 1747-UIC Being Used With The New USB Port. I Know I Can Communicate On Com1 With My USB Adaptor Due To Programming IDEC PLC
NEWBBIE Take It Easy On Me
thanks In Advance
To add a little more information:
The 1747-PIC ia a RS232 to RS485 converter. It electrically converts the information coming from a serial port. The information will be using the DH485 protocol.
The 1747-UIC recieves DF1 protocol via the USB. It converts the protocol to DH485. It then provides this converted protocol in two electrical formats - RS232 and RS485.
good afternoon all I had to pull out the old 1747-pic module my question it has a 25 pin connection I need to go to a 9 pin connection do pin 2...
1,609
Im getting trouble with my plc using 1747 pic connection, i found this solution: http://www.plctalk.net/qanda/archive/index.php/t-63919.html, but...
2,268
Working with dmroeder to get a AB PIC adapter to work under Windows using SP3 update. Installed his SP3 fix file and still can not get RSlinx to...
25
6,273
Hello everyone, I received a Fatal error message when added driver 1747-PIC, after that I closed that window and driver was added normally, but...
2,156
We are trying to connect to an Allen Bradley SLC 500 Processor 1747-L40A with a 1747-PIC box. PIC box to laptop connection is with 9-pin to...
4,063
