1747 pic
knome
Dec 2010
Muncie Indiana
My PIC works fine on a 5:03 processor on XP service pack 2 but if I load service pack 3 the PIC stops communicating and if I load linx lite 2.54 I have to have service pack 3 I cant even communicate with my serial cable.
Ron
I can't tell if there is a question in there somewhere but you are correct that the PIC does NOT work with Windows XP SP3.
can the firm ware on my panel view 550 be updated cat #2711-K5A2 FRN 1.07 My pic modual wont communicate with it until I load Linx classic 2.57 and to do that it says I have to install service pack 3
good afternoon all I had to pull out the old 1747-pic module my question it has a 25 pin connection I need to go to a 9 pin connection do pin 2...
1,623
Im getting trouble with my plc using 1747 pic connection, i found this solution: http://www.plctalk.net/qanda/archive/index.php/t-63919.html, but...
2,282
Working with dmroeder to get a AB PIC adapter to work under Windows using SP3 update. Installed his SP3 fix file and still can not get RSlinx to...
25
6,284
Hello everyone, I received a Fatal error message when added driver 1747-PIC, after that I closed that window and driver was added normally, but...
2,162
We are trying to connect to an Allen Bradley SLC 500 Processor 1747-L40A with a 1747-PIC box. PIC box to laptop connection is with 9-pin to...
4,069
