1747sn to 1794IE8
roxusa
Nov 2008
NJ
994
Does anyone know of an AB publication for RIO BTW/BTR
to the 1794IE8, The only literature I find on AB site is PLC-3
& PLC-5 I am using 1747SN, I have used RIO before with the 1794 ASB but not BTR/BTW to an anilog unit. I have used them with panelview..............Thanks
Thanks, I am using an L532 SER. E so I use the BTR & BTW function block
I think they are correct but I am not sure about the bits set in control block of BTW......need to do more research
That is a recent Processor. I am sure it is in the Manual, but if you look at the Instruction Help in RSLogix500, one of the three Help Pages describes the Control Status Bits.
Stu....
The problem started with an error 208 in my PV900 after a program change and download to my slc 5/04. The logic had worked for over 2 years...
2,772
Hi currently my work parther an I are working into trying to visualize a set of values on a PanelView 550 that is connected tru a RIO connection...
6,529
Hi, I am trying to get some flexi IO communicating. The scanner has its steady green light on The G file is all the default values.The first two...
5,229
J
I am having trouble with an existing SLC5/05. It was working fine but after power cycle, we lost data to all but 1 1794-IE8 module. I looked at...
3,118
We have a PLC5 system that is connected to a Flex I/O rack via ControlNet (1794ANC15). I have read that flex I/O is hot swappable, but can the...
1,661
