1756 DNB Status Structure
ben
Jun 2002
37
Hi All,
I am working with a 1756DNB and looking to use the Device failure register to pick up that eg my node 01 E3 device has lost communications. I would like to use this feature in my CLX program.
I can’t seem to find any information on how this register works, and hence which address should I use to display I have a device failure?
Can anyone give me an URL, so I can do some more reading up on this, I can’t seem to find much else but the basics?
Ben
The Device Failure registers are an array of 8 SINT tags, so that one bit corresponds to one possible DeviceNet node number of 0 to 63.
Local:1:S.DeviceFailureRegister[0] - [7].
There will be a "1" in the bit position corresponding to the node number if there has been a communication failure. If communications with Node 23 fails, for example, bit
Local:1:S.DeviceFailureRegister[2].7 will be "1".
I actually prefer to use the Device Status array. That provides one SINT for each node, instead of 1 bit per node, and gives the status code for the slave device connection.
With the Device Status array, a failure on Node 23 would result in
Local:1:S.DeviceStatus[23] having a value of "72" or "78" (connection failure or messaging failure).
This is especially handy for devices that might also experience size mismatches, Idle states, or identity mismatches.
That makes it clear. For a while I wondered why the fault moved (also) into the first sint location about 11 sec's after disconnection of a node. Of course its the scanner at node 0 showing the failure.
Clever stuff. I must try harder not to bother you lot.
Hi good day PLC Talk Community. Can somebody please shed light on 1756-DNB Diagnotic Counters and what they mean. DNB Scanner Diagnostic...
570
Hello, PLCS.net guys. Currently I'm making the safety communication on 1756-DNB to DX200 Yaskawa contoller. I made the setting and assigned the...
628
Numatics devicenet module G2-2 is replaced with new unit and address is configured from address 63 to address 1. Encountered error E#77 for Node 1...
1,037
Hi everybody, I have with me the following: 1. 1756-L73S controller + 55L7SP safety partner 2. 1756-ENBT 3. 1756-DNB 3a. 1791DS-IB8XOB8 3b...
2,241
i'm trying to interface a 1756-dnb to a couple devices. i've got the rsnetworx configuration complete and dowwnloaded to the device. when i go...
3,191
