1756-DNB USB port???
gmferg
Feb 2008
Modesto, CA
340
Does anyone know what the deal is with the USB port which is on the front of the latest 1756-DNBs?
Does this allow me to go online with the DNet network? Is there a new driver in Linx for this?
What happened to the little black button which made it fast and easy to setup a new DNB?
The 1756-DNB Series C has rotary switches on the side for MACID and data rate; that should make it even easier than the black button.
You're right about the USB connection; RSLinx 2.51 and later has the driver. You can get online with the DeviceNet (browsing is faster than ever) or anything else in the backplane (like the CPU). The 1756-CN2/B and 1756-EN2T/EN2F share the same chipset and have this USB connector as well.
There's a Technote (AID# 50064) on some of the new features in the /C module.
A user on one of the Forums pointed out a different between the /B and /C modules when sending a message with an Attribute value of zero, and there was a firmware update almost immediately after launch (you want 10.005 firmware) but otherwise the Series C module is pretty much a drop-in replacement for its predecessors.
Hi good day PLC Talk Community. Can somebody please shed light on 1756-DNB Diagnotic Counters and what they mean. DNB Scanner Diagnostic...
594
Hello, PLCS.net guys. Currently I'm making the safety communication on 1756-DNB to DX200 Yaskawa contoller. I made the setting and assigned the...
630
Numatics devicenet module G2-2 is replaced with new unit and address is configured from address 63 to address 1. Encountered error E#77 for Node 1...
1,044
Hi everybody, I have with me the following: 1. 1756-L73S controller + 55L7SP safety partner 2. 1756-ENBT 3. 1756-DNB 3a. 1791DS-IB8XOB8 3b...
2,260
i'm trying to interface a 1756-dnb to a couple devices. i've got the rsnetworx configuration complete and dowwnloaded to the device. when i go...
3,214
