1756-EN2TR Module Mismatch
Joshua37
Aug 2014
Dallas
47
Hi All,
Need a little insight on the following-
Have a ControlLogix L71 with 1756-EN2TR communication adapters. Each has revision 10.007, while in my running project it is 3.1 which I can only increase up to 5. I have set the keying to compatible mode. The whole system is communicating, but in the properties I get the message "Physical module does not match configured module". Should I be concerned with this ?
I have attached the module property snaps for clarity.
There is a tech-note regarding this on the RA website: 575816. It essentially asks to install an AOP.
Is this all that I need to do ??
Yes, the card is working fine.
But still, I installed the module profile and revved the card up to the latest FW.
Now it's all good :)
Good to hear. Like I said its subjective, but personally I like a clean program without complaints on the I/O so that the I/O light actually means something! To many times I find that no one cares about these errors as long as the I/O is working.
(y)
I am using Allen Bradley PLC 1756-L81E and EIP module 1756-EN2TR for Ethernet/IP communication. My communication works fine but in Get-Attribute...
225
Hi. Rockwell learning curve 132-1b. I was having trouble to change IP address on a EN2TR. Finally found out that I need to change the IP...
865
Hi All, Got a funny issue. I have a 1756-L85EP and a 1756-EN2TR in the same chase. The client asked for the Ferrari and the 3 lane highway!!! We...
193
Good morning, I have a system on 1756 L73 that works with supervisor on EN2TR modules. Everything works correctly, except that EN2TR (1) with...
532
Hello Everyone, What is the best practice for DLR set up. Should I keep all VFDs on one DLR and FlexIO on another or it would make sense to put...
2,646
