1756-ENBT fault
JamesWSY
Jul 2005
Jakarta
81
Hi..
I try to setup 1756-ENBT/A on CLX chassis, setup (from RSLinx) IP: 192.168.100.10 and found fault on module with error code 16#0022. On front of ENBT module, running message 192.168.100.10 with OK indication. How to solve the problem? Any idea?
Thank you.
James
we us the 1756-enbt for communication , but others set the same ip address , so my 1756-enbt has fault : Duplicate IP Mac **:**:**:**:**:** ...
1,645
1756-ENBT Series A F/W Rev. 4.008. While I was on holidays, this failed in an 1756 I/O Rack. They changed it out with a spare unit. I have it...
5,733
We've been getting this fault intermittently on a 1756-ENBT module. PLC needs to be powered down to reset it. The ENBT module revision is 4.8...
2,390
I am in the process of changing over my old DH+ network to Ethernet/IP.I have about a 1/3 of the devices switched over and ran into a problem with...
7,130
please using the usb can i assign any ip address that i want ?
153
