I have a 1756-IF8 module, I am ready to collect 4-20MA current signal, the module parameters can see the following screenshot. Some routines, I do not quite understand.
INT1 [6] DATA TYPE is INT, -1000 converted into what is real?
4-20 mA signal is converted into -18.46582 how it?
ADATA [111] The DATA TYPER is DINT, ADATA [111] is equal to -3,702, then converted into a real number is equal to the number?
Routine in the data does not seem to convert the actual value, I would like to ask is how to be converted into actual values, simply to say that I would like to know 1756-IF8 module receives 4-20MA signal, how can be converted to REAL DINT INT
and so on.
TheHigh engiuneering how the set? 26,784.0 how this case is determined? Thanks
and so on.
