Kilowatt76
I'm new here and very much a beginner. I had a question about this AB 1756-IF8 Analog card and how to correctly wire it. I looked in the manual and I was trying to figure out this card. The panel is being supplied with 120V AC and I using 120V AC Input/Output modules as well. Does the the 1756-IF8 require a separate 24V DC power supply to the card? I'm use to using the 1769-IF4 where you supply (+) and (-) 24V to terminals on the card. I will be connecting a 4-20 mA signal from a flow meter transmitter. I appreciate any help with this!
Is there anyone that can show a cad drawing on how this should be properly wired?
Thanks,
Kilowatt76
Thanks,
Kilowatt76
