Hi guys
I have a customer that would like to make changes to there system. I cannot get online to see the system running to confirm what i would like to do.
They have a Micro 1200 with channel 0 talking Modbus to the 9 pin din connector on a 1761-net-aic module. The dh-485 term block is wired to 6 yaskawa drives. The db9 / rs-232 connector on the bottom of the aic is open. The HMI / Programming port on the micro is connected to a pv 600 (AB 2711-TBC16L1) .
My computer does not have a proper serial port, i use a tripp-lite usb to serial converter. It works well as you all know. In this situation, to get online through the net-aic, do i need the 1747-UIC?
I don't have much experience with these modules and i'm having some trouble getting the proper info needed.
Thanks All
Ted
Thanks All
Ted
