1761-NET AIC to Panelview 550 b5a1
Magnaform
Jul 2007
MI
I have a panelview 550 2711 B5A1 and a Micrologix 1200 connected to a 1761 NET AIC. Is there a way to communicate between the 6 pin DH485 connector on the AIC and the 3 pin RIO connecter on the 550? Is a RIO to DH485 converter necesary?
Thanks,
Jim
The ML1200 or ML series of controllers do not support RIO. Your going to have to change your PV550 to a DF1 or DH485 unit. Or change your ML1200 to a SLC5/? with a RIO scanner.
I have never heard of a RIO to DH485 converter and even if there was one
it would not work with your ML1200.
Hello, currently I have a micrologix 1200 (1762-L40AWAR )connected to an HMI panelview 600(2711-T6C3L1X) via the 1761-net-aic module, I want to...
1,814
I've attached pics, below. I'm in the field right now an am trying to communicate to the Micrologix 1500 through the 1761-NET-AIC (Ugh!) to...
1,960
The manual for the 1761-NET-AIC shows connecting a PC to DH485 network with a 1761-PM-02 cable. Is this done using a DF1 driver set to...
1,073
A customer of mine has a ML 1500 LRP connected to a Net-AIC+ via the mini din connector (CH 0 of plc to port 2 of AIC) from this AIC then connects...
1,795
I have a bunch of ML1000 PLCs on a DH485 network using 1761-NET-AIC modules and we are replacing the ML1000s with ML1400s. Once all of the...
2,017
