1761-net-aic+
Wow, only about a year late.
I finally found one.
Did you draw this one yourself?
The one I finally found is a little different than yours. I'll attach it.
beerchug
It looks like you did end up getting it from that ABECAD/RAISE thing.
Do you what kind of AutoCad image that is? I can render the image, and it looks 3d, but I don't think it 's really a model.
Hello, currently I have a micrologix 1200 (1762-L40AWAR )connected to an HMI panelview 600(2711-T6C3L1X) via the 1761-net-aic module, I want to...
1,809
I've attached pics, below. I'm in the field right now an am trying to communicate to the Micrologix 1500 through the 1761-NET-AIC (Ugh!) to...
1,956
The manual for the 1761-NET-AIC shows connecting a PC to DH485 network with a 1761-PM-02 cable. Is this done using a DF1 driver set to...
1,073
A customer of mine has a ML 1500 LRP connected to a Net-AIC+ via the mini din connector (CH 0 of plc to port 2 of AIC) from this AIC then connects...
1,794
I have a bunch of ML1000 PLCs on a DH485 network using 1761-NET-AIC modules and we are replacing the ML1000s with ML1400s. Once all of the...
2,014
