sheppawc
Hello, I am trying to connect to my SLC500 L40A using a 1761-NET-ENI (SER A)
and a 1761-NET-AIC (SER A) converter. I am using RSLinx Gateway Edition v2.2 on a Windows 2000 Gateway Laptop with a serial port. I was able to configure my
1761-NET-AIC (SER A) with a valid IP address in the correct subnet and I can ping it and bring it up in IE. I am also able to connect to the PLC using the PIC/AIC driver in RSLinx. I think the problem is the serial side of the ENI converter. I am unclear on what driver I should use in RSLinx to connect to the ENI. I tried to use the
AB_ETH-1, DH485 but it comes up with “Unrecognized Device” and a red X. My IP address is entered correctly. 192.168.1.25, any help would be greatly appreciative. Thank you.
