http://www.plctalk.net/qanda/showthread.php?p=588476
-- Oiginally Posted by shawn_75 View Post
Attempt a firmware update over ethernet to 3.22 (I think). I've never had an ENI fault steady red so I don;t know if this will work. All my series D ENIs began behaving quite nicely when I updated from 3.21.---
Thanks. Steady Red Solved.
Before the upgrade 3.22, Net Eni Behavior
No RS232 Communication works
No Ethernet Comunications works
No com re-director Works
No Net/ENI Utility Works via (ethernet and RS232)
Reset Net/Eni via Programming ladder Logic over RSLogix 500/5000.(No works)
No Boot DHCP WORKS.
Every moment when Connected Net/Eni to SLC or L34... FAULT the controller
NO RSLinx Detection.
When I add the IP Address on the Web browser, web page blocked (No Works)
The only thing that it works were the CMD ping. ( only works whith the last IP in this case was 129.123.226.30)
Upgrade
Only Download the firmware.
Open and put the last Ip Addresss 129.123.226.30
After Upgrade.
All the stuff that I mentioned runs perfect.
I hope these info helps others.
Regards.
-AJ:book:
No Boot DHCP WORKS.
Upgrade
After Upgrade.
Regards.
-AJ:book:
