1761-net-eni
plcisgreat
May 2005
Norfolk,NE
58
Can someone explain to me, step by step, how to setup the 1761-net-eni. Including how to setup the IP address,etc. I've read the manual and it's not working me. I have RSlinx 2.5 conneting to a SLC 5/04. Thanks.
CH. 4 of the user's manual outlines the setup process in a very "step-by-step" way, gives you screen shots as well as the link to download the configuration utility. What specific part is throwing you?
Setup the ENI
using serial port. I have a "no response, check cable, etc". Verified cable with micrologix 1000 and with a different CPU. This is a used ENI, could it be faulty?
This what have.
I want to connect to a SLC5/04 with DF1/ PMO2 Cable, PC to ENI series C
Downloaded the EDS file and registered file. 0001000C00630300
I have the ENI utility software. This a series C.
Settings: 232 baud 19200
Utililties: COM 1 Baud 19200
IP 010.003.251.010
Gateway 255.255.255.000
Saved to RAM, ROM. No problems so far.
RSLinx version 2.50
config driver as AB_ETH-1 IP ADD. 010.003.251.010
Unrecognized device Yellow "?" with Red "X"
I tried this and when I typed in the IP address of 10.003.251.010 in rslinx and clicked on add new the IP address changes to 10.3.251.8 then it show's up as a yellow question mark with a red x through it. Try to enter in 10.3.251.10 then click on add new this made my eni show up in linx
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
153
Good afternoon guys, does anyone recommend a direct replacement part for Allen Bradley's 1761-NET-ENI devices? We have a lot of these in our plant...
1,013
Hello, currently I have a micrologix 1200 (1762-L40AWAR )connected to an HMI panelview 600(2711-T6C3L1X) via the 1761-net-aic module, I want to...
1,797
I have decided that instead of upgrading the drives & plc at the same time on my project i would just do the drives for now as just getting them...
23
9,033
Our company has many of Rockwell's beloved NET-ENI modules to get SLC 5/03's onto our network. They have the issue of faulting out if more than 3...
1,925
