1762-if2of2 issue
sanket007
May 2013
pune
i couldn't configure AI flow sensor to the AI channel of 1762-IF2OF2. I get tremendous variations in the values of the flow sensor, also the garbage values to the modules shows the variations even if the Flow sensor is not connected to the module.
Have you checked the signal coming from the sensor?
If that itself is varying rapidly, then the module does not have any problem and is just showing what it is getting.It either means that the sensor has problem or your process variable itself is varying in such a fashion.
If Your process variable itself is erratic and you want to smooth out the input signal then you can program a filter as discussed in this Thread.
Thanks for the solution i think the flow sensor needs to be calibrated, if ever problem persists i will go with your filter solution or revert back to you...
Calibration is not going to cure an erratic signal.
Is the wiring shielded? Noise from near by wiring?
I have a Moog hydraulic servo valve that operates a cylinder that moves up and down. I have the 1762-if2of2 hooked up to it and sending the 4-20ma...
2,631
Hi Sirs, Good Day. I have a simple questions/clarification regarding the connection of "negative channel" and "com" of the analog input module...
1,731
I was trying to use a Micrologix 1100 and a 1762-if2of2 Analog IO card to demonstrate A/D and D/A conversion. Simple ladder logic Enter a value...
3,894
Hey all, Been working on a little project using a Micrologic 1100, Just added this 2-in/2-out analog module (1762-If3Of2)to my project, and a...
2,201
So I got my ML1100 up and running last night, and tonight Im trying to connect an analog in/out module 1762-IF2OF2. The problem is that the green...
2,263
