1762-L24BXB MVM Instruction
Feb 2012
São Paulo
53
Good Morning Sirs,
I'm using a MVM instruction to turn on/off my PLC's outputs. I'm using, meanwhile, the outputs O:2/0 to O:2/3.
Then I use my MVM instruction just with the first 4 bits of a B3:122 moving it to my O:2.0.
The problem is, the first three outputs worked fine when I started the program, but when I need to turn on the O:2/3 the MVM seems not to move my bit to the output.
Is there something missing?
The ladder I'm using is:
Hello, I have a Micrologix 1200 1762-L24BXB PLC and as soon as I power it up with nothing connected to it, the power LED and the fault LED both...
3,748
Does anyone know what type of thermister for the CJC on a 1762-IT4 thermocouple card? I have searched everywhere and can not find. I can not see...
626
Hi every master,Recently i met a fault about 1762-L40BWA 1,When i get the PLC, The Fault light is lighting, I am not remember the fault message,I...
720
Hello everybody and master,I met a problem about ML1200.It is described as below: 1,When i got this PLC,The FAULT light is lighting, My computer...
1,113
I have 1769-IF4 module and 1766 micrologix 1400 series B controller, when connecting Analogue input in module it's showing maximum values of...
1,696
