1769 CJC jumper compatible with 1756 card?
mylespetro
Dec 2015
NS
740
Hey everyone,
Ran into a bit of a hiccup today, we (I) forgot to order the CJC kit for a 1756 ControlLogix thermocouple card, and we need some ASAP. We found a 1769 CompactLogix thermocouple card at our office on a bench setup that does have two CJC jumpers, would these work with the 1756 card, or are they incompatible? Definitely won't forget ordering the jumpers again o_O (I definitely will)
Thanks!
I doubt they are. CJC's are typically specific to the device they are made for (different resistance values at different temperatures). You could check and see what part number comes with each device and if they are the same then they probably would work but if they are different then it won't work (it will miss-calibrate your device).
Anyone know a fix for this? 1769-IT6, 2 modules both have same problem. Setup for K tc, 1x engineering units data, degrees F, 60Hz filter...
4,253
Does anybody know what they use for the Cold Junction Compensator on a 1769-L27ERM? From measuring it, it seems to be just a generic NTP...
1,373
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
98
I have a CompactLogix 1769-L31 and need to communicate with it. I only have studio 5000 on my computer. However, when I try to start a new project...
398
I have a 1769-L24ER-BB1B and I am trying to flash it to 34xx, its flashing red and faulted, when I try to flash it I get a popup stating it needs...
256
