1769 ethernet IP panelview factory talk
TheClint
Jan 2013
Jamaica
Hello all,
I am having issues with a new processor that I have not had before. I am able to point to my offline tag file and browse tags. I am able to test my screens when I connect to my controller(L30ER). Everything works correctly when using my computer as the HMI.
My problem is when I make my runtime. I make it in 6.0, I am using a panelview pluc 6 terminal. After I get through the runtime conversion I get this error:
.MER Conversion Error
Start RSLinx Enterprise Conversion Messages
WARNING: UNSUPPORTED DEVICE DETECTED. SHORTCUT NAME"CONTROLLER" DEVICE NAME"L30ER"
then it goes on to say that if i have a patch on my HMI that the runtime may work fine. CONTROLLER is my shortcut. L30ER is my controller name in RSLinx enterprise.
I know this is a problem with my path, but I dont understand why it will work in design mode and not in runtime mode.
thanks in advance for the help.
FActory talk version 6.1
RSLogix v20
My panelview is version 6.0
I have seen this a few times with the L30ER - You can just ignore it - it's only a warning, the runtime file will still function on the PV - never caused any issue on my HMI.
Hi Guys, I want to connect my 1769-L36ERM to a different network domain, is it possible to do it using only the dual ports in the Controller? Or...
236
Hi, I recently tried to change the IP address of my 1769-L35E Series A, since doing this the MS indicator is flashing red and the NS indicator is...
936
We have a machine that has a 1769-L33ER and we were wanting to connect it to our plant network. Currently has a local network for drives and HMI...
862
So I have a system that is running on DeviceNet. We have been having nothing but problems with it for the last 3 years. I am trying to switch...
1,284
Good Day Everyone I could use some advice and/or direction on how to connect remotely using my Wifi to a 1769-L32e. I set up the Ethernet/IP while...
1,398
