1769-hsc Reset
JamesWSY
Jul 2005
Jakarta
81
I used 1769-HSC, CompactLogix processor 1769-L32E with incremental encoder to measure sheet length. I need help hot to reset the current count value (Local:1:I.Ctr0CurrentCount)to zero? Any idea? or sample RSLogix 5K?
Thank you for help.
James
If you have the hsc counting properly, you would use the following.
My HSC was in slot 13.
I would latch the reset on rung 15 and then reset it on rung 10 once itw as latched.
Rung 10 (XIC) Local:13:O.Ctr0SoftPreset OTU Local:13:O.Ctr0SoftPreset
Rung 15 Conditions and then (OTL) Local:13:O.Ctr0SoftPreset
I've got an issue with resetting a counter to 0 on a Micrologix 1500 with a 1769-HSC card. The preset is configured in the IO configuration for 0...
4,860
I followed the procedure to reset, in both ways. The first way it to set the preset value to 0 in the CtrnPreset tag in the configuration array...
1,967
Hello all. I am having trouble setting up my HSC to count pulses from a prox switch. I have it wired to the prox and I see the .InputStateA0...
1,373
Here is my hail Mary pass I have a wheel that produces 33 pulses per revolution. The RPM of that wheel will be anywhere from 25.21 to 62.7 Pulses...
4,705
Hello all. I have an issue that keeps plaguing me. The system has a 1769-L24ER processor and a 1769 HSC card. I am using CH.0 for tracking...
1,469
